PrakashPrasad's avatar
PrakashPrasad
3 years ago
Issues using IOWR for SPI communications
I am having difficulty using the IOWR and IORD functions in NIOS II.
We have a ENUM like below:
#define BASE 0x80
typedef enum SPI_REGISTERS_tag
READ_REG_5_E = 0x00,
WRITE_REG_0_E = 0x01,
SPI_STATUS_WORD = 0x02,
SPI_CONTROL_WORD = 0x03
} SPI_REGISTERS;
For SPI communication to send data we need to write 0x80 at I/O address 0x8C
When we use the below statement it works fine:
*(U32*)0x8C = 0x80;
But with below code the objective is not met:
IOWR(BASE, SPI_CONTROL_WORD, 0x80);
Which translates to below code:
__builtin_stwio (((void *)(((alt_u8*)(0x80)) + (((SPI_CONTROL_WORD)) * (32/8)))), (0x80));
When I read back the value written using above statement for address 8C I get value 0x10?
We tried to use IOWR32_DRIECT() but still the same issue. We verified the assembly instruction and they differend in stw / stwio instruction note that we are using data cache:
*(U32*)0x8C = 0x80;
00C02304 movi r3,0x8C ; r3,140
00802004 movi r2,0x80 ; r2,128
18800015 stw r2,0x0(r3) ; r2,0(r3)
18800035 stwio r2,0x0(r3) ; r2,0(r3)
I also tried making the CACHE size to 0 but no success.
What wrong am I doing and fix required to achieve the objective?
  • Hi,
    Thank you.
    Kelly Jialin, GOH
  • I have updated - it seems that the CACHE is not getting updated. But another unfortunate findings was that the functions to update cache (alt_dcache_flush_all()) are excluded from our library - so I cannot use them. I tried the below code and it worked:
    Refer Doc - https://www.intel.com/content/www/us/en/docs/programmable/683282/current/cache-considerations-for-writing-program.html
    * Assume new instruction in r4 and
    * instruction address already in r5.
    stw r4, 0(r5)
    flushd 0(r5)
    flushi r5
    flushp
    Hence in below C code I implemented below assembly instruction code to achieve it:
    .... C code ....
    __asm__ ("movi r3,0x80");
    __asm__ ("movi r2,0x8c");
    __asm__ ("stw r3,0x0(r2)");
    __asm__ volatile("flushd 0x0(r2)");
    .... C code ....
    The above code worked though should I be using below code:
    __asm__ ("flushd 0x0(r2)");
    __asm__ ("flushi r2");
    __asm__("flushp");
    My question now is can we directly use r2 and r3 registers as above. Which of the above two code sections I can use? Should we not get the value of them and restore back after the flushd assembly instruction - if so please let me know how in a C program I can achieve this?
    Also should we always make use r2 and r3 register? Can we use any register as used above?
    What would be the best code to implement in C code otherwise?
