AragornStrider's avatar
AragornStrider
6 days ago
Is VCCPD = 3.3V and VCCIO = 2.5V allowed on an Arria V?
I am currently using an Arria V 5AGXMA1D4F27 device. I would like to use 3.3V on VCCPD and 2.5V on VCCIO for the IO bank. The intent is to have JTAG programming done at 3.3V(the processor doing the programming has 3.3V GPIOs). All pins on the bank will be using 2.5V for normal operation in addition to having true LVDS pins on the same bank after configuration.
I could not find any documentation for this. It would be of great help to have a confirmation on if this is valid?
Thank you for your time.
1 Reply
  • Hi,
    Short answer: No, VCCPD = 3.3 V with VCCIO = 2.5 V is not a supported combination for Arria V.
    You need to ensure the compatibility between the VCCPD and VCCIO for an I/O bank. Refer here:
    https://docs.altera.com/r/docs/683213/current/arria-v-device-handbook-volume-1-device-interfaces-and-integration/guideline-ensure-compatible-vccio-and-vccpd-voltage-in-the-same-bank
    Below link is the supported VCCPD / VCCIO combinations for LVDS:
    https://docs.altera.com/r/docs/683213/current/arria-v-device-handbook-volume-1-device-interfaces-and-integration/i/o-standards-voltage-levels-in-arria-v-devices
    Notice that VCCPD = 3.3 V is not listed as a supported combination at all for banks with LVDS. The only supported VCCPD value for a 2.5 V VCCIO bank (with LVDS) is 2.5 V.
    This is also consistent with the other I/O standards.
    In another document, from the footnote 119, you can see the compatible combination VCCPD and VCCIO.
    Recommended operating conditions for VCCPD
    What you should do instead
    Set VCCPD = 2.5 V for your 2.5 V VCCIO bank. This is the correct and documented combination for an I/O bank running 2.5 V LVCMOS and true LVDS.
    For your JTAG interface at 3.3 V: the JTAG pins (TDI, TDO, TMS, TCK) on Arria V are powered by VCCPD of the bank in which the pin resides. You may need to isolate this bank specifically only for configuration purposes.
    Aqid
