13 years agoIs my Cyclone 2 in self protection mode ?
Hi all I have a relatively simple application running on a Cyclone 2 EP2c8, where the FPGA is the master for high speed bidirectional communication signals to another module. During operatio...
13 years ago --- Quote Start --- Thanks for the clarification. I think you are correct that it is probably due to a timing issue with the FPGA ending up in a undefined state. Cheers. --- Quote End --- Verified the issue is due to a synchronization issue between a signal at a pin (asynchronous) and internally clocked signal. Adding a synchronous delay to pin signal before the logic operation removed the need for reset. Thanks, Adrian
