11 years ago
Is it a synthesizable verilog coding?
I delete it.
    In that particular example it *should* be fine, because it is effectively equivalent to:
    wire rst_n = !(B & C);
    always @ (posedge A or negedge rst_n) begin
        if(~rst_n) begin
            E <= 0;
        end else if (D) begin
            E <= F;
        end
    end
    A is still used as the clock, and D is used as a clock enable.
    --- Quote Start ---
        if(~rst_n) begin
            E <= 0;
            E <= F;
        end
    end
    --- Quote End ---
    Thank you.
    After post this, I try use Quartus "Technology Map Viewer", and it give me the answer.
    Thank you anyway, you're very kind.
