11 years agoIs it a synthesizable verilog coding?
I delete it.
11 years ago --- Quote Start --- In that particular example it *should* be fine, because it is effectively equivalent to:
wire rst_n = !(B & C);
always @ (posedge A or negedge rst_n) begin
if(~rst_n) begin
E <= 0;
end else if (D) begin
E <= F;
end
end
A is still used as the clock, and D is used as a clock enable. --- Quote End --- Thank you. After post this, I try use Quartus "Technology Map Viewer", and it give me the answer. Thank you anyway, you're very kind.
