16 years agoIs anybody interested on remote support
I am, because the BCD counter with logic (like the one attached) is not counting down correctly. what should I do?
16 years agoWhat do you mean by "is not counting down correctly"?
You are using gated clocks in your design, which is a very bad habit and can generate all sort of problems. You should directly connect all your clocks to the clock pin and use clock/count enables instead.
