16 years agoIs anybody interested on remote support
I am, because the BCD counter with logic (like the one attached) is not counting down correctly. what should I do?
Plus you're using internal tri-states. These just get converted to muxes at the end of the day (unless they're actually on external IO pins). It just slows down synthesis time.
What do you mean by "is not counting down correctly"?
You are using gated clocks in your design, which is a very bad habit and can generate all sort of problems. You should directly connect all your clocks to the clock pin and use clock/count enables instead. - Altera_Forum
