ip-make-simscript not generating script for Riviera
- 4 years ago
Can I check what is written in the spd_list.txt?
I think your script is not direct to the .spd file.
I try to create a simple project with PLL IP, generate HDL for Riviera only, run Analysis and synthesis.
In GUI, Generate Simulator Setup Script for IP works.
In command, it works with the rivierapro_setup.tcl generated.
ip-make-simscript --spd=C:\quartus_project\quartus_pro\simulation_test\pll\pll.spd --output-directory=C:\quartus_project\quartus_pro\simulation_test\pll\simulation --simulator=RIVIERA
You can try a simpler project to test the flow whether it works.
- grspbr4 years ago
I think you are right. I may have the wrong files listed in the spd list. I will work on this some more. Also, I think I misunderstood the use of the --system-file option
