ip-make-simscript not generating script for Riviera
- 4 years ago
Can I check what is written in the spd_list.txt?
I think your script is not direct to the .spd file.
I try to create a simple project with PLL IP, generate HDL for Riviera only, run Analysis and synthesis.
In GUI, Generate Simulator Setup Script for IP works.
In command, it works with the rivierapro_setup.tcl generated.
ip-make-simscript --spd=C:\quartus_project\quartus_pro\simulation_test\pll\pll.spd --output-directory=C:\quartus_project\quartus_pro\simulation_test\pll\simulation --simulator=RIVIERA
You can try a simpler project to test the flow whether it works.
I have no problem generating these files with Platform Designer or with the Quartus GUI. But I think I found the issue with the script...
It's failing because it can't find the setup tcl files for all the supported simulators even though I am only targeting Riviera.
So what I did was generate use:
