16 years ago
I/O standard of cyclone III device EP3C55 bank 1
I am using cyclone iii device EP3C55, and assigned pins(DDR2-SDRAM) in bank 1 to sstl-18 class i I/O standard, but Quartus II shows the error messages like this:
error: I/O bank 1 cannot select VCCIO of 1.8V which is required for pin DDR2_ADDR[2] with I/O standard SSTL-18 Class I
error: VCCIO 1.8V is not compatible with the VCCIO requirement of the I/O bank 1 imposed by the selected configuration scheme
Can't pins in bank 1 be assigned to SSTL-18 CLASS I I/O standard?
Thank you!
    I am sure that I set all of them to "Use as regular I/Os" but still Quarus is producing the error as shown below(Selected configuration other than AS)
    Error: Can't place multiple pins assigned to pin location Pin_F3 (IOPAD_X0_Y17_N14)
    Info: Pin mem_we_n is assigned to pin location Pin_F3 (IOPAD_X0_Y17_N14)
    Info: Pin ~ALTERA_DCLK~ is assigned to pin location Pin_F3 (IOPAD_X0_Y17_N14)
    As I konw, you can avoid the error by the way you mentioned even you're not using AS.
    Make sure that you have set all Dual purpose pins to "Use as regular I/Os".
    Hey guys,
    Even I faced the same problem, the bank 1 is set to 1.8 v for my memory signals, what I need to do now?
    I tried changing configuration but it leads to another error as follows
    Error: Can't place multiple pins assigned to pin location Pin_D2 (IOPAD_X0_Y22_N21)
    Info: Pin mem_addr[12] is assigned to pin location Pin_D2 (IOPAD_X0_Y22_N21)
    Info: Pin ~ALTERA_ASDO_DATA1~ is assigned to pin location Pin_D2 (IOPAD_X0_Y22_N21)
    Actually this error can be avoided by setting all Dual purpose pins to "Use as regular I/Os" in device options when using Active Serial Configauration(AS) but for other configurations even I set them to use as regular I/Os Quartus is erroring out, Can you help me.
    If you are using AS, B1 must supplied by 3.3V (at least with EPCSxx chips).
    --- Quote Start ---
    I guess, you are using AS configuration scheme, that also uses B1?
    --- Quote End ---
    Actually yes, isn't it right? what kind of AS configuration scheme shall I use? Thanks.
