16 years agoIO-Port switching using VHDL
Hello, i have a VHDL-Project (Quartus II 9.1) wich has 96 Outputs. Every Output can be switched on/off by several entities. Every Entity wich can switch one or more Ports has a process like thi...
16 years agoIt is not important where the date is comming from, the only important thing is that a internal port of a entity is given out at a port (1 of 96) wich can be defined at runtime. The user has to take care not to define the same portnumber for two entities.
