16 years agoIO-Port switching using VHDL
Hello, i have a VHDL-Project (Quartus II 9.1) wich has 96 Outputs. Every Output can be switched on/off by several entities. Every Entity wich can switch one or more Ports has a process like thi...
16 years agoHello,
the portnumbers are not constant. The entities do not know wich ports they have to switch at compilation time. The portnumbers are set at runtime, because they can change. Thanks Paddy
