15 years ago
Interrupt Problem
Currently i am working on low level driver for Nand Flash in NIOS II.In my system following component are included DDR_SDRAM,JTAG_UART,PERFORMANCE COUNTER,PIO(LED),NFC(Nand flash controller).In my sytem i use interrupt on PIO Base.
in my low level API like read and write i use it as following code.
write()
//data write code
//enable NFC
while(intrstat == 0);
intrstat = 0;//globel variable
read()
//data read code
//enable NFC
intrstat = 0;
main()
IOWR(LED_BASE,0,0);
alt_irq_register(NFC_IRQ,edge_capture_ptr,handle_nfc_interrupts);
alt_irq_enable(NFC_BASE);
write();
read();
static void handle_nfc_interrupts(void* context, alt_u32 id)
volatile int* irq_capture_ptr = (volatile int*) context;
printf("Into the nfc_handler:\n");
alt_irq_disable(NFC_BASE);
IORD(NFC_BASE,NFC_STATUS);
IOWR(LED_BASE,0,1);
intrstat = 1;
my problem is when i call the write or read API it goes in infinite loop and also not call the ISR for it.so pls give me help what change i needed in above code..............
    @phillip
    finaly................................................
    i reslove my problem.
    this issue occurs from IP side so i tell about it to IP devloper for my system
    and they give me new .sof after some modification and then all my code gone very well.
    Thanks @philipp to continuesly give me help,
    Jayesh
    --- Quote Start ---
    reslove my problem.
    --- Quote End ---
    Great to hear!
    Well, I couldn't really help you......
    but anyway you are welcome!
    Best wishes to India!
    Philipp
