16 years ago
interface DAC in VHDL
I´m trying to interface a DAC converter in VHDL with board DSP Development Board for Stratix II Edition, in order to send a pulse, but i´m new in this type of design language.
so i need some help. I´m interested in the vhdl code if it would be possible. Thank you very much.
    --- Quote Start ---
    mode should be a std_logic output port, then:
    mode <= '1';
    --- Quote End ---
    Or you can connect this ping directly to +3.3v. Or leave this pin free.
    mode <= '1';
    i know that mode is a dac pin , but i mean what 1'b1 or 1'b0 does mean ? i think it doesn't exist in vhdl
    thank you ARTEM_BOND
    i didn't study verilog but i try to understand this code and transform it to vhdl
    i have just one question
    what do you mean by this line "assign mode = 1'b1;" ?
    It's verilog..
    module top
    data2dac,
    clk,
    clkA,
    wrtA,
    mode
    output reg [13:0] data2dacA;
    input clk;
    output clkA;
    output wrtA;
    output mode;
    assign mode = 1'b1;
    assign clkA = clk;
    assign wrtA = clk;
    reg [13:0] tmp;
    always @(posedge clk)begin
    tmp <= tmp +1'h1; //saw waive.
    data2dacA <= tmp;// 4 speed
    end
    endmodule;
