16 years agointer board JTAG communication
Hi all, I'm using Altera Cyclone III board, can i use the JTAG header to configure another FPGA board (the altera Cyclone III bord send the programmer file by JTAG)?
16 years agoThere are some JTAG signals on the HSMC connector, but they can only be used to add something to the board's JTAG chain. This means that your second boards would only be configurable by the kit's integrated USB blaster or JTAG connector.
In your case, you would need to write a custom IP to read the programming file and regenerate JTAG signals. You could then use regular I/Os from the HSMC connector and connect them to the second board's JTAG header.
