8 years agoIntel HLS Compiler (aka i++) Error:No definition found for speed grade '-7' Cyclone10
Hi guys, I've installed Intel HLS Compiler (aka i++) together with Intel® Quartus® Prime Pro Edition 17.1 to try it out. After setup, I can run the test in "HLS Getting Started Guide" document succes...
8 years agoOK, after checking the info from i++ --help, I found I can use FPGA family instead of the part code. So I changed my command into:
$ i++ mips.c -march="Cyclone 10 GX" -o test-fpga and it works. (Be careful, the double quotes for the family name are necessary, otherwise it can't be recognized.)
