Saikiranbelana's avatar
Saikiranbelana
3 years ago
Intel Devstack-OpenCL unable to detect PAC Cards
Intel Development Acceleration Stack for OpenCL is not detecting the Arria 10 PAC Cards on our server. It's looking for PAC drivers which cannot be found at the OpenCL_BSP installation path.
The Cards can be detected using `lspci` and `OPAE drivers` but not with `aocl diagnose` command:
System Specs:
OS: ubuntu - 18.04
The following is the log:
server2@ubuntu:~$ sudo fpgainfo fme
Board Management Controller, microcontroller FW version 26895
Last Power Down Cause: POK_CORE
Last Reset Cause: None
//****** FME ******//
Object Id                     : 0xEE00001
PCIe s:b:d:f                  : 0000:AF:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Bitstream Id                  : 0x124000200000367
Bitstream Version             : 1.2.4
Pr Interface Id               : 38d782e3-b612-5343-b934-2433e348ac4c
Boot Page                     : user
Object Id                     : 0xEE00000
PCIe s:b:d:f                  : 0000:86:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Boot Page                     : user
server2@ubuntu:~$ source ~/inteldevstack/init_env.sh
export QUARTUS_HOME=/opt/intelFPGA_pro/quartus_19.2.0b57/quartus
export OPAE_PLATFORM_ROOT=/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv
export AOCL_BOARD_PACKAGE_ROOT=/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp
source /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec/setup_permissions.sh
$OPAE_PLATFORM_ROOT/bin is in PATH already
sudo cp /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/sw/afu_platform_info /usr/bin/
export INTELFPGAOCLSDKROOT=/opt/intelFPGA_pro/quartus_19.2.0b57/hld
export ALTERAOCLSDKROOT=/opt/intelFPGA_pro/quartus_19.2.0b57/hld
$QUARTUS_HOME/bin is in PATH already
source /opt/intelFPGA_pro/quartus_19.2.0b57/hld/init_opencl.sh
server2@ubuntu:~$ aocl diagnose
ICD System Diagnostics
Using the following location for ICD installation:
        /etc/OpenCL/vendors
Found 2 icd entry at that location:
        /etc/OpenCL/vendors/Altera.icd
        /etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
the following OpenCL libraries are referenced in the icd files:
        libalteracl.so
        libintelocl_emu.so
checking LD_LIBRARY_PATH for registered libraries:
        libalteracl.so was registered on the system at /opt/intelFPGA_pro/quartus_19.2.0b57/hld/host/linux64/lib
        libintelocl_emu.so was registered on the system at /opt/intelFPGA_pro/quartus_19.2.0b57/hld/host/linux64/lib
Using the following location for fcd installations:
        /opt/Intel/OpenCL/Boards
Found 2 fcd entry at that location:
        /opt/Intel/OpenCL/Boards/a10_ref.fcd
        /opt/Intel/OpenCL/Boards/dcp_bsp.fcd
the following OpenCL libraries are referenced in the fcd files:
        /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref/linux64/lib/libaltera_a10_ref_mmd.so
        /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so
        /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref/linux64/lib/libaltera_a10_ref_mmd.so was registered on the system.
        /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so was registered on the system.
Number of Platforms = 2
        1. Intel(R) FPGA SDK for OpenCL(TM)                             | Intel(R) Corporation           | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.4
        2. Intel(R) FPGA Emulation Platform for OpenCL(TM)              | Intel(R) Corporation           | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
ICD diagnostics PASSED
BSP Diagnostics
Error initializing DMA: no memory
Error initializing mmd dma
Error closing DMA
Error initializing bsp
Error closing DMA
Warning:
No devices attached for package:
Unable to find the kernel mode driver.
Please make sure you have properly installed the driver. To install the driver, run
      aocl install
DIAGNOSTIC_FAILED
Warning:
Error closing DMA
Error closing DMA
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
server2@ubuntu:~$ aocl install
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] y
aocl install: /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp is already registered in the system, please uninstall it before reinstalling
server2@ubuntu:~$
Please help us fix this @intel @BoonBengT_Altera @JohnT_Intel
Thank you,
Saikiran
  • Hi @JohnT_Intel , Here's the output for lspci
    server2@ubuntu:~$ lspci | grep acce
    af:00.0 Processing accelerators: Intel Corporation Device 09c4
    The FPGA is still available and only shows with lspci and fpgainfo. I think the problem is with the drivers. When I move the FPGA to a different system, It works there.
  • JohnT_Altera's avatar
    JohnT_Altera
    Can you try "lspci -vv | grep acce" to get the kernel driver information.
  • Here's the output for `lspci -vv | grep acce`:
    server2@ubuntu:~$ sudo lspci -vv | grep acce
    for `lspci -vv` :
    	Subsystem: Intel Corporation Device 0000
    	Physical Slot: 5
    	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
    	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    	Latency: 0, Cache Line Size: 64 bytes
    	Interrupt: pin A routed to IRQ 39
    	NUMA node: 1
    	Region 0: Memory at dbffff00000 (64-bit, prefetchable) [size=512K]
    	Region 2: Memory at dbfffe00000 (64-bit, prefetchable) [size=1M]
    	Capabilities: [68] MSI-X: Enable+ Count=7 Masked-
    		Vector table: BAR=0 offset=00009000
    		PBA: BAR=0 offset=0000a000
    	Capabilities: [78] Power Management version 3
    		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
    		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
    	Capabilities: [80] Express (v2) Endpoint, MSI 00
    		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
    			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
    		DevCtl:	Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
    			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
    			MaxPayload 256 bytes, MaxReadReq 4096 bytes
    		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
    		LnkCap:	Port #0, Speed 8GT/s, Width x8, ASPM not supported, Exit Latency L0s <4us, L1 <1us
    			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
    		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk+
    			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
    		LnkSta:	Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
    		DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported
    		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
    		LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
    			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
    			 Compliance De-emphasis: -6dB
    		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
    			 EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
    	Capabilities: [100 v2] Advanced Error Reporting
    		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
    		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
    		UESvrt:	DLP- SDES+ TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
    		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
    		CEMsk:	RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr+
    		AERCap:	First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
    	Capabilities: [160 v1] Alternative Routing-ID Interpretation (ARI)
    		ARICap:	MFVC- ACS-, Next Function: 0
    		ARICtl:	MFVC- ACS-, Function Group: 0
    	Capabilities: [200 v1] Single Root I/O Virtualization (SR-IOV)
    		IOVCap:	Migration-, Interrupt Message Number: 000
    		IOVCtl:	Enable- Migration- Interrupt- MSE- ARIHierarchy+
    		IOVSta:	Migration-
    		Initial VFs: 1, Total VFs: 1, Number of VFs: 0, Function Dependency Link: 00
    		VF offset: 1, stride: 1, Device ID: 09c5
    		Supported Page Size: 00000553, System Page Size: 00000001
    		Region 0: Memory at 00000dbfffd00000 (64-bit, prefetchable)
    		Region 4: Memory at 00000dbffff80000 (64-bit, prefetchable)
    		VF Migration: offset: 00000000, BIR: 0
    	Capabilities: [280 v1] #19
    	Kernel driver in use: intel-fpga-pci
    	Kernel modules: intel_fpga_pci
    JohnT_Altera
    Thanks for providing the logfile. From the logfile, it looks like it automatically loaded with default PCIe driver. Please performed "modprobe -r intel-fpga-pci" then only performed "aocl install".
    JohnT_Altera
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    • Saikiranbelana's avatar
      Saikiranbelana
      Sorry for the delayed response.
      I couldn't fix the error occurring. So, I had to reinstall the OS and install the inteldevstack on it. It works now.
      Thanks, @JohnT_Intel for the support.
