RBibe
6 years agoIntel Cyclone 10 GX w. DDR3 Memory using PLL as Clock
Hi, can i use the internal PLL of Cyclone 10 GX instead of using dedicated Clock input for DDR3 memory Clock? All Development boards are using a dedicated clock, so is this mandatory? Thanks!
Rahul_S_Intel1
6 years agoHi ,
Kidnly follow the recommendation from the ug to connect to the clock to the emif Ip,
The PLL reference clock pin may be placed in the address and command I/O bank or in a data I/O bank, there is no implication on timing.
Reference page no: 20
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20116.pdf
