Michael2021
1 year agoIntel® Arria® 10 FPGA – Intel DisplayPort 8K RX-Only Design Example
Hello, I'm trying to look at this design. I downloaded the A10_DP_RX_FMC_PRO.par file and compiled it with Quartus Pro 21.1. I'm trying to compile the CPU program file in the Additional_Files dire...
VenT_Altera
1 year agoHi @Michael2021,
Thank you for the updates.
Adding the resolution to "nios2-bsp-update-settings : command not found" here for the Community and future references:
From the log you shared, when compiling debug.c to obj/default/ ./debug.o, it failed. There is a message complaining:
…Make: nios2-elf-gcc: No such file or directory
Please resolve this as well. As the command is part of the Nios® V/II Embedded Design Suite (EDS), I think you may continue the discussion in the above forum thread.
Please let me know if you can generate the .elf file once the above issue is resolved.
Ven
