14 years agoInstantiating AHDL module in VHDL without component part
I really like the idea of instantiating a module without a component part and then in main code using entity work. :HA2 : entity work.halfadder port map (s1,cin,sum,c2);The idea came from this link: http://vhdlguru.blogspot.com/2010/03/entity-instantiation-easy-way-of-port.html It works fine for my VHDL modules, but when i have some AHDL modules in my design and i want to instantiate them the same way, Quartus II gives me an error: --- Quote Start --- Error (10481): VHDL Use Clause error at main.vhd(155): design library "work" does not contain primary unit "ahdl_module" --- Quote End --- Is there a way to work it around and not to use components when instantiating ahdl modules ? Perhaps quartus puts ahdl modules into some different library, or adds some name in the entity of that module - i wasn't able to find it. best regards madness2 Replies
thanks for the reply :) i won't be trying to do that. best regards madness - Altera_Forum
Nope. For mixed language you need to use components, because the VHDL compiler has no knowledge of the AHDL, hence you need it to be a black box - which is what components are for.
