Gianfranco9635's avatar
Gianfranco9635
2 years ago
Inout port became output
Hi guys,
i'm trying to create a project based on a Bridge SPI to Avalon. In my top entity i have a signal that is defined as "INOUT" and that represent the I/O of my fpga (name signal is LSASBUS). My problem regards the eda netlist writer that create the file .vo. If i change something in my top entity and i compile the project, all work good. if i re-compile it, my project doesn't work. This happen because in the .vo file, the "INOUT" port became "Output" and i don't know why. I'm using quartus lite versione 20.1.
How can i resolve? i include my top level file in vhdl.
FPGA_USER.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library lpm;
use lpm.lpm_components.all;
library altera_mf;
use altera_mf.altera_mf_components.all;
entity user is
port
-- Main clock inputs
mainClk : in std_logic;
slowClk : in std_logic;
-- Main reset input
reset : in std_logic;
-- MCU interface (UART, I2C)
mcuUartTx : in std_logic;
mcuUartRx : out std_logic;
mcuI2cScl : in std_logic;
mcuI2cSda : inout std_logic;
-- Logic state analyzer/stimulator
lsasBus : inout std_logic_vector( 31 downto 0 );
-- Dip switches
switches : in std_logic_vector( 7 downto 0 );
-- LEDs
leds : out std_logic_vector( 3 downto 0 );
state_out : out std_logic_vector(4 downto 0)
end user;
architecture behavioural of user is
signal clk: std_logic;
signal pllLock: std_logic;
signal lsasBusIn: std_logic_vector( 31 downto 0 );
signal lsasBusOut: std_logic_vector( 31 downto 0 );
signal lsasBusEn: std_logic_vector( 31 downto 0 ) := ( others => '0' );
signal mcuI2cDIn: std_logic;
signal mcuI2CDOut: std_logic;
signal mcuI2cEn: std_logic := '0';
signal state : std_logic_vector(4 downto 0);
component myAltPll
PORT
areset : IN STD_LOGIC := '0';
inclk0 : IN STD_LOGIC := '0';
c0 : OUT STD_LOGIC ;
locked : OUT STD_LOGIC
end component;
component SPI_Avalon_System
PORT
clk_clk : in std_logic; -- clk.clk
reset_reset_n : in std_logic; -- reset.reset_n
spi_mosi : in std_logic; -- spi.mosi
spi_ss : in std_logic; -- .ss
spi_miso : out std_logic; -- .miso
spi_sclk : in std_logic; -- .sclk
en_miso : out std_logic;
state : out std_logic_vector(4 downto 0);
ss_sys : out std_logic
end component;
begin
--* Main clock PLL
myAltPll_inst : myAltPll PORT MAP (
areset => reset,
inclk0 => mainClk,
c0 => clk,
locked => pllLock
--* LEDs
leds <= switches( 3 downto 0 );
--* lsasBus : inout std_logic_vector( 31 downto 0 )
lsasBusIn <= lsasBus;
lsasBus_tristate:
process( lsasBusEn, lsasBusOut, lsasBusIn ) is
begin
for index in 0 to 31 loop
if lsasBusEn( index ) = '1' then
lsasBus( index ) <= lsasBusOut ( index );
else
lsasBus( index ) <= 'Z';
end if;
end loop;
end process;
system : SPI_Avalon_System
port map(
clk_clk => mainClk,
reset_reset_n => reset,
spi_mosi => lsasBusIn(15),
spi_sclk => lsasBusIn(13),
spi_ss => lsasBusIn(12),
spi_miso => lsasBusOut(14),
en_miso => lsasBusEn(14),
state => state,
ss_sys => lsasBusOut(5)
lsasBusOut(4 downto 0) <= state(4 downto 0);
lsasBusEn(5 downto 0) <= (others => '1');
lsasBusOut(8)<=lsasBusIn(13);
lsasBusEn(8)<= '1';
state_out <= state;
end behavioural;
FPGA-USER.vo --- FIRST COMPILATION
`timescale 1 ps/ 1 ps
module user (
mainClk,
slowClk,
reset,
mcuUartTx,
mcuUartRx,
mcuI2cScl,
mcuI2cSda,
lsasBus,
switches,
leds,
state_out);
input mainClk;
input slowClk;
input reset;
input mcuUartTx;
output mcuUartRx;
input mcuI2cScl;
inout mcuI2cSda;
inout [31:0] lsasBus;
input [7:0] switches;
output [3:0] leds;
output [4:0] state_out;
FPGA-USER.vo ----SECOND COMPILATION
module user (
mainClk,
slowClk,
reset,
mcuUartTx,
mcuUartRx,
mcuI2cScl,
mcuI2cSda,
lsasBus,
switches,
leds,
state_out);
input mainClk;
input slowClk;
input reset;
input mcuUartTx;
output mcuUartRx;
input mcuI2cScl;
output mcuI2cSda;
output [31:0] lsasBus;
output [3:0] leds;
  • ShengN_altera's avatar
    ShengN_altera
    Or you may also create tcl script like below and run with quartus_sh -t:
    package require ::quartus::project
    package require ::quartus::flow
    project_open -revision test test
    project_clean
    execute_flow -compile
    ShengN_altera
    Yes, you can create a tcl script for example like test.tcl. Then add the command below to the tcl script:
    quartus_sh --clean test
    quartus_sh --flow compile test
    And then source the tcl script to clean and compile
    [Edited] If for quartus_sh --clean test, project name test can't be used then use with the .qpf one like test.qpf
    ShengN_altera
    Check this KDB https://www.intel.com/content/www/us/en/support/programmable/articles/000086339.html, this is known previous problem and had been concluded using the workaround clean the project before running compilation to resolve the problem. Based on previous internal team reply: There is no capacity or further step taken for this.
    The problem only exists in linux version but not in window version.
    Sheng
    • Gianfranco9635's avatar
      Gianfranco9635
      I’m using quartus lite 20.1 in Windows.
      if I use clean project under project tab, it works good. But if I want to clean it automatically every time that I want to compile, what I should do? Create a script and add it on project?
      thanks
  • FvM's avatar
    FvM
    just a guess, you see inout port implemented as output only because tri-state output is always enabled in your code. If so, you'd see respective synthesis warnings.
      Gianfranco9635
      The tri-state outputs are not always active. In fact my lsasBusEn is initialize to 0.
      Maybe I’m wrong. How would you fix my code?
      Thank you!!
