efe373
3 years agoInitializing inferred RAM from a text file
I have written a simple dual-port RAM in VHDL following the single-port RAM example from Quartus, and I want to initialize this RAM using an external text file containing binary values. How...
ShengN_altera
3 years agoHi @efe373 ,
Just go through your reply, as mentioned in previous post:
The In-System Memory Content Editor works by turning single‑port RAM blocks into dual-port RAM blocks. One port is connected to your clock domain and data signals, and the other port is connected to the JTAG clock and data signals for editing or viewing.
Noted: Only single-port memorys can therefore be used with ISME, because if you use a dual-port RAM the second port is already in use by your design and is therefore not available to ISME.
Let me know if you have any further concern.
Sheng
