17 years agoInitial DFF values after FPGA programming
Normally I design my all my logic with an asynchronous reset, so this is not an issue, but I have recently come across an area where we might reload the FPGA via nCONFIG to reset it, and not have Use...
17 years ago --- Quote Start --- I was going to say the same. But I wonder just out of curiosity, and would like yours and other experts opinion, if this is really 100% foolproof. Isn't it possible that the async reset release could produce setup/hold violations on the register output? If this is possible, then the next register in the counter could, in theory, become metastable. --- Quote End --- If this is the case, are the bits in your counter/shift register acting as synchronization registers? Since the asynchronous signal is a reset/preset, we are not violating the flip-flop's Data input to rising-clock setup time, but instead de-asserting a preset while the clock is rising. I assume from what FmV said that the problem is some registers interpret this as a reset followed by a rising clock, and other interpreting it as a rising clock followed by a reset. I do not know if this can lead to metastability the same way setup time violations can.
