11 years agoInferring two multipliers in one DPS block in verilog/VHDL, Cyclone V
The module dsp1a infers two DSP blocks. Why not one DSP? Is there any way to force synthesiser to use one DSP block?
I would like to use Independent Multiplier Mode of DSP block. While the similar module dsp1a+dsp1b (top level is now dsp1b) uses one DSP block, as expected. module dsp1a(input wire [7:0] a1, input wire [7:0] b1, input wire [7:0] a2, input wire [7:0] b2, output wire [15:0] y1, output wire [15:0] y2 );//infers 2 DSP when top-level: BAD assign y1 = a1 * b1; assign y2 = a2 * b2; endmodule module dsp1b(input wire [7:0] a1, input wire [7:0] b1, input wire [7:0] a2, input wire [7:0] b2, output wire [15:0] y );//infers 1 DSP when top-level: OK wire [15:0] y1; wire [15:0] y2; dsp1a dsp1 (.a1(a1), .b1(b1), .a2(a2), .b2(b2), .y1(y1), .y2(y2)); assign y = y1 + y2; endmodule Thanks in advance12 Replies
Thank you for reply. But I tried inferring 26 multipliers on device having 25 DSP blocks and it not fit. So automatic merging multipliers to DSP seems doesn't occur. I tried also different speed/balance optimization.
this KDB solution might answered our question:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03192013_756.html
