AyushIND
1 year agoIndustrial grade FPGA firmware image can run on extended grade for cyclone 10GX
Our primary choice for the project is the Extended grade Cyclone 10 GX (10CX105YU484E5G), as it meets the required operating temperature range (0°C to 100°C) and is more cost-effective. However, in ...
Farabi_Altera
1 year agoHello,
The difference between -I (Industrial) and -E (Extended) grade is just temperature support of its package. Both can run the firmware. FPGA designers only need to take care of the timing closure of each design.
regards,
Farabi
- AyushIND1 year ago
Thanks for replying, So are you suggesting Industrial grade firmware can run on Extended grade without any issue ?
