16 years ago
Indalid Pin A1 on EP2C8F256I8.
Hello.
It turned out that pinA1 marked wrong on real device\chip. I suppose all documents from altera.com is OK, but real chip is wrong.
On real device G8 short-circuited to G9, and K8 to K9. I see tracks of core power net by viewing bottom side of chip.
I have 7 devices.
Marking:
EP2C8F256I8
K BBB9Y0537A
MALAYSIA
NBB9Y33702
3Q3KA5T0E
I understand mirror\flip effects.
As result, i must soldering this chip to board (Board designed by standard EDA library, and this library is OK). How to rotate a chip? CW or CCW? All power nets is symmetrical.
Photos - later (forum has limits)
    --- Quote Start ---
    You should contact your supplier.
    --- Quote End ---
    I changed supplier. Later (after delivering some other components) i will contact about this problem.
    --- Quote Start ---
    These parts could be counterfeit parts.
    --- Quote End ---
    Probably yes. Or somebody change marking of parts.
    --- Quote Start ---
    Did you already test the one which has been soldered?
    --- Quote End ---
    Yes, but only programmed in passive by ByteBlaster with successful result.
    --- Quote Start ---
    The last one in the video doesn't have the copper pattern (or it is not visible in the video). How do you determine A1 on this device?
    --- Quote End ---
    This chip has other colour of bottom. Dark dark green or black. Rectangle was visible in the reflection.
    --- Quote Start ---
    Again, thanks for sharing this.
    Good luck with your project,
    -- Ton
    --- Quote End ---
    --- Quote Start ---
    I recorded video for you.
    --- Quote End ---
    I've seen the video. This is absurd. You should contact your supplier. These parts could be counterfeit parts. Did you already test the one which has been soldered?
    -- Ton
    --- Quote Start ---
    Could you also post an image of the top of the chip and mark pin A1 with an arrow like you did on the bottom image.
    --- Quote End ---
    I recorded video for you. I suppose you will not use this against Altera company.
    Avi file by link:
    w w w .fayloobmennik.net/111344
    password for access: 123
    As you see on video A1 pin located at top-left corner on bottom side of chip, and it must be at bottom-left corner on top side of chip.
    Statistic: 1 chip is good, 4 chip CCW, and 2 chip CW (1 is already soldered).
    Thanks for sharing this.
    I would highly appriciate that.
    Thanks in advance, Ton
    --- Quote Start ---
    If I read that right... All the documents are right, only the chip is wrong.
    --- Quote End ---
    Yes. Now we try to determine position by simply upload dummy firmware by Byte-Blaster.
    --- Quote Start ---
    ... I suppose all documents from altera.com is OK, but real chip is wrong. ...
    --- Quote End ---
    :confused:
    That is a very unique way of looking at a problem.:)
