16 years agoIndalid Pin A1 on EP2C8F256I8.
Hello. It turned out that pinA1 marked wrong on real device\chip. I suppose all documents from altera.com is OK, but real chip is wrong. On real device G8 short-circuited to G9, and K8 to ...
16 years ago --- Quote Start --- Could you also post an image of the top of the chip and mark pin A1 with an arrow like you did on the bottom image. --- Quote End --- I recorded video for you. I suppose you will not use this against Altera company. Avi file by link: w w w .fayloobmennik.net/111344 password for access: 123 As you see on video A1 pin located at top-left corner on bottom side of chip, and it must be at bottom-left corner on top side of chip. Statistic: 1 chip is good, 4 chip CCW, and 2 chip CW (1 is already soldered).
