16 years agoIndalid Pin A1 on EP2C8F256I8.
Hello. It turned out that pinA1 marked wrong on real device\chip. I suppose all documents from altera.com is OK, but real chip is wrong. On real device G8 short-circuited to G9, and K8 to ...
16 years ago --- Quote Start --- I recorded video for you. --- Quote End --- I've seen the video. This is absurd. You should contact your supplier. These parts could be counterfeit parts. Did you already test the one which has been soldered? The last one in the video doesn't have the copper pattern (or it is not visible in the video). How do you determine A1 on this device? Again, thanks for sharing this. Good luck with your project, -- Ton
