ieee float and fixed point packages
Included the ieee.fixed and float as shown below in top.vhdl. The files are in Quartus/ieee/2008 folder.
library ieee;
use ieee.fixed_pkg_vhdl2008.all;
use ieee.float_pkg_vhdl2008.all;
In compilation, the following error and not sure what these means.
Error (10481): VHDL Use Clause error at PDA_361000893_TOP_FPGA.vhd(31): design library "ieee" does not contain primary unit "fixed_pkg_vhdl2008". Verify that the primary unit exists in the library and has been successfully compiled.
Error (10800): VHDL error at PDA_361000893_TOP_FPGA.vhd(31): selected name in use clause is not an expanded name
Error (10481): VHDL Use Clause error at PDA_361000893_TOP_FPGA.vhd(32): design library "ieee" does not contain primary unit "float_pkg_vhdl2008". Verify that the primary unit exists in the library and has been successfully compiled.
- Nurina
Did you add those libraries to your project? Go to Assignments>Settings>Libraries to add them.
Also, which Quartus version are you using? VHDL 2008 are only supported on certain Quartus versions: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf
Nurina
- GD76
I tried that and got an error. So removed that and added straight in VHDL file the following and worked.
library ieee_proposed;
use ieee_proposed.fixed_float_types.all;
use ieee_proposed.fixed_pkg.all;The error is about the library not compiled. But don't know how to compile the ieee library. Thanks anyway.
- Nurina
Thank you for sharing your solution. I’m glad that your problem is solved, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
