ieee float and fixed point packages
I tried that and got an error. So removed that and added straight in VHDL file the following and worked.
library ieee_proposed;
use ieee_proposed.fixed_float_types.all;
use ieee_proposed.fixed_pkg.all;
The error is about the library not compiled. But don't know how to compile the ieee library. Thanks anyway.
Thank you for sharing your solution. I’m glad that your problem is solved, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
