16 years ago
I want knowing POF file format structures.
hello, everyone.
I can open a .pof file and program this to the EPCS16 device if i know
the length of the header so i can remove it first. The header includes
info about Quartus build date/version/device/comment e.t.c
The .pof file also includes a signature, but since the useful data
only exists until about 1/3 into the file, this signature is also
removed when programming..
Does anyone know the .pof file format? I really need to know this:
1. Where is the header-length is specified?
2. What does the different "unknown" bytes in the header (except for
the obvious ascii coded strings) specify?
My application can also read the contens of the flash and save it to a
file. It would be really useful if this could be saved in a .pof valid
format, and written back using the quartus programming tool, so:
3. What does the Quartus programming tool look for to determine if
the .pof is valid? (checksum? probably some of the info requested in
1, 2?)
4. What does the signature/footer describe?
Thanks so much.
