17 years agoI want knowing POF file format structures.
hello, everyone. I want knowing POF file format structures. I can open a .pof file and program this to the EPCS16 device if i know the length of the header so i can remove it first. T...
13 years ago --- Quote Start --- Have you considered a different file format? rbf for example http://www.altera.com/support/kdb/solutions/rd01212004_4844.html Just contains the data --- Quote End --- hi vernmid i want to download the rbf data in the EPCS4, does all the rbf data need to be download ? how? only the least significant bit (LSB) of each data byte is loaded first? i have read out all the EPCS4 data and found there are some different between RBF data and EPCS4 data
