SHuai's avatar
SHuai
7 years ago
I have a problem with program. when i download a sof file with jtag,it successd in case of msel value 001(ps/fpp mode).But if msel set to 011(as mode),it fail,error ID:209014.
The chip is 10AS016E3F27.
In ps/fpp mode,jtag detect 2 device,10AS016E3 and SOPVHPS
In as mode,jtag detect 1 device,10AS016E3
I have connect nCONFIG,nSTATUS,CONF_DONE through a 10 k resistor to VCCPGM,nCE to GND.
How should i solve the problem.
Thank you!
    • SHuai's avatar
      SHuai
      The problem has been solved.
      The hardware engineer made a mistake that there are differences between boards and schematic design.
      when I set msel value 011,actual setting is 101.It is a wrong configuration.
      Thanks​
      • ShafiqY_Intel's avatar
        ShafiqY_Intel
        Hi SHuai,
        I am glad to hear that the issue is resolved.
        I will close this thread. If you have further question, please submit a new forum thread.
    ShafiqY_Intel
    Hi SHuai,
    The reason of this error is the CONF_DONE pin in the device did not go high at the end of configuration.
    Here are some factors of this error:
    • Communications cables not securely connected
    • Incorrect device selected
    • No power to target system
    • Device nCE pin not connected to GND
    Here some workaround you can try:
    • Remove the SD card and reinsert it in the bard farm machines
    • Can you kindly try to reduce your TCK frequency to 6 MHz (default value)?
    Below link is the command to change TCK frequency (on page 14= 2.8. Changing the TCK Frequency) https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf#page=14
    I hope this will help.
    • SHuai's avatar
      SHuai
      I had reduce TCK frequency to 6 MHz but the problems remain​.
      Thanks​
