zlan01
6 years agoI design a board with max10,and do not design the reset input for max10, how can I generate a internal reset ?
Can I use the locked output of pll to generate a reset signal for my design? And what is the best reset mode for max10 ?using a input reset or generating a reset signal just in FPGA ? For my board,t...
ak6dn
6 years agoNope, I don't like that approach. Can't rely on SYS_CLK being valid if PLL is not locked.
Here is what I do. I generate an async reset at powerup ONLY. Sync to PLL clock via dual rank sync circuit if sync reset is desired instead.
// PowerUP Reset Logic
// generate a 500ms reset pulse on initial powerup
`ifdef SIMULATION
reg [24:0] pup_count = 25'd24999900;
`else
reg [24:0] pup_count = 25'd0;
`endif
reg pup_reset = 1'b1;
always @(posedge CLOCK_50)
begin
pup_count <= #TPD pup_count + 1'd1;
if (pup_count == 25'd25000000) pup_reset <= #TPD 1'b0;
end
wire reset = pup_reset;PLL logic looks like this:
// Altera PLL Clock module
// Transform external crystal clock to our internal CPU clock
wire pll_locked;
wire CLOCK_CPU;
pll pll
( .inclk0 (CLOCK_50), // input clock
.locked (pll_locked), // status output
.c0 (CLOCK_CPU) // output clock
wire clk = CLOCK_CPU;
