zlan01
6 years agoI design a board with max10,and do not design the reset input for max10, how can I generate a internal reset ?
Can I use the locked output of pll to generate a reset signal for my design? And what is the best reset mode for max10 ?using a input reset or generating a reset signal just in FPGA ? For my board,t...
zlan01
6 years agooh,thanks very much!
what about use the output of the pll to driver the reset generation logic ?
Can the code below generate a reset correctly?
always@(posedge sys_clk ) //sys_clk is a output of the pll and is 200Mhz
begin
if(~locked_sig)
reset_cnt <= 30'd0;
else if(reset_cnt < 30'd200_000_005 ) // 1second to configure
reset_cnt <= reset_cnt + 30'd1;
end
assign rst_n = (reset_cnt == 30'd200_000_001)?1'b0:1'b1;
