NReddy
8 years agoi am finding Short between VCC and GND pins of EP1K100 ACEX Series IC. What could be the reason other than ESD on I/Os which could lead to this .. any idea..?
To confirm this i have taken out all passives between power rails of IC and other connecting devices on Board but still there is short in power rails ( 2.5V and 3.3V) of IC .
JScho6
8 years agoIf this is only happening on a few boards, then you're probably looking for a different cause. The defect you're describing may be a latch-up, which means that both the push and the pull driver of the CMOS output are driven at the same time, shorting out the IO voltage to GND.
I have hardly ever seen this on an FPGA. but I've seen it many times on CPLDs, ever since the AMD MACH series. The most likely cause for a latch-up on CPLDs is power spikes and drops. Check voltage ripple and step response on your regulators. You can always improve step response with a larger cap and lower ESR, but with multiple voltages involved on an FPGA board, you may need to go into deeper analysis for possible cross-regulation problems.
