14 years ago"HREAD" is used but not declared"-Read text image data Error
Hi, I try simulate testbench code for read text image data (project example). I have includes all the package required (textio), but when I compile it I get this error: "Error (10482): V...
14 years agoYes, you can only run the testbench in modelsim. Textio is not appropriate for synthesys, hence why you cannot compile in Quartus.
The error you are getting is a type missmatch, you probably need to convert them using the to_signed(int, size) function. If you are unfamiliar with this, and textio, I suggest you read some VHDL tutorials, as these are very basic parts of VHDL.
