9 years agoHPS Configuration in QSys: Why is hps_io exported?
When I configure the HPS in QSys (Quartus Prime 16.0), I can determine the Pin muxing in the "Peripheral Pins" section. In the "Peripherals Mux Table" on the bottom, I can see how the various control...
9 years agoDrTobbe you are correct, except the last part. Drive strength and slew rate assignments should take effect, but you hit the nail on the head why those interfaces need to be exposed. The HPS pins in Arria/Cyclone V are limited compared to the FPGA pins so drive strength and slew rate are probably the only assignments you can set, the rest of the I/O features are simply not present.
It's important that you *do not* manually assign the HPS pins because the HPS component in Qsys hands this information off to Quartus already and if you make a conflicting pin location assignment you'll probably get a confusing error message out of Quartus when the compilation fails.
