phuongnn0
1 year agoHow to use Signal tab to verify signal PHY Lite for Parallel Interfaces FPGA IP
Hi, I am new for FPGA I am using Arria 10 - 10AX115S2F45I1SG My design uses PHY Lite for Parallel Interfaces FPGA IP. When I enable signal tab in Asembler. I have problem when synthesiz...
sstrell
1 year agoYou are most likely tapping a post-fit node in your design that cannot be tapped. Look over the Node List in your Signal Tap file and see if you can tap either a pre-synthesis version of the node or another signal that feeds into the node you want to look at.
