15 years agoHow to use M9k block memory
Hi all; I have two dev. kits. The main development kit is De2. I want to use M9K block memories in my host development kit(Cyclone III dev. board) via HSMC interface. How can I make?
15 years agoI wouldn't recommend doing this if you want to run the interface at any significant speed without placing a standard high speed interface between the two FPGAs.
At the end of the day what type of latencies/throughput/clock speeds are you looking to have in your design? Wiring all the on-chip memory signals through the HSMC connector as a parallel bus may not give you the throughput you are looking for without pipelining and proper timing constraints (remember there is a lot of delay doing chip-to-chip communication)
