19 years agoHow to use LVDS?
in datasheet,i find maybe it isn't similar to use LVDS in Cyclone1,cyclone2,and cyclone3, so what can i do if i want to use LVDS? 1,does it need resistor? 2,how many wire i need ? in my opin...
19 years agoHi All ,
I remember that Altera had a ASI / SDI development board in 2004 There were two versions of boards , One of them was a low cost solution , and another one was a high-en solution The device on the low cost ASI / SDI development board was EP1C6T144C6 As there was no dedicated CDR circuitry in Cyclone I FPGA Altera had a reference design on CDR algorithm in Cyclone I FPGA That was a reference design doing CDR for a 270Mbps LVDS signal (Which is a kind of over-sampling actually) Say Data Rate = 270Mbps Input Crystal Freq = 27MHz Use PLL to generate a clock of 337.5MHz , we call it SCLK Then use the PLL to generate another clock of 337.5MHz with 90 degrees phase shift we call this clock signal sclk90 Invert this 2 clock signals , SCLK (0 degree phase shift) SCLK90 (90 degree phase shift) ISCLK (180 degree phase shift) ISCLK90 (270 degree phase shift) Then we sample the input data with these 4 clock signals And finally resynchronize the data to 27MHz , the output is a 10 bit data Virtually this is a 5 times sampling (270 x 5 / 4 = 337.5) Is Steven talking about this kind of CDR in Low Cost FPGA ?
