- Farabi
Can you try this : remove the location assignment on it. Otherwise, to remove the critical warning use the QSF assignment 'set_global_assignment -name AUTO_RESERVE_CLKUSR_FOR_CALIBRATION OFF'.
regards,
Farabi- Steve-Mowbray-ENL
Hi Farabi
Rather than experimenting with cludge fixes I am focussing on the Platform Designer automatic generated:
(*altera_attribute = "-name SDC_STATEMENT \"if { [get_collection_size [get_pins -compatibility_mode -nowarn ~ALTERA_CLKUSR~~ibuf|o]] > 0 } { create_clock -name ~ALTERA_CLKUSR~ -period 8 [get_pins -compatibility_mode -nowarn ~ALTERA_CLKUSR~~ibuf|o] }\"" *)associated with the transceiver reset sequencer instance in the design -- doesn't seem to be an obvious IP parameter to tell the instance that CLKUSR is at 100MHz rather than 125MHz...
- FvM
Hi Steve,
pin connection guidelines say about clkusr pin
This pin can be used as a GPIO pin only if you are not using
transceivers, not using HMC, and not using this pin as a user
supplied configuration clock.
Frank- Steve-Mowbray-ENL
Thanks Frank -- yes that is my understanding -- my concern is by explicitly assigning the CLKUSR pin does Quartus infer that the pin is now a GPIO pin thus excluding transceiver use -- doing a project build now so will hopefully have some Quartus reporting to discuss shortly. Regards Steve
UPDATE: build complete with interesting critical warning:
Critical Warning (18326): The design pin 'clkusr' has been assigned to CLKUSR pin location 'Y15'. Quartus Prime auto-reserves the CLKUSR pin for calibration of transceivers and certain IOs. If the pin 'clkusr' will not be assigned a 100-125MHz clock, you must remove the location assignment on it. Otherwise, to remove the critical warning use the QSF assignment 'set_global_assignment -name AUTO_RESERVE_CLKUSR_FOR_CALIBRATION OFF'.So optimistic interpretation of the above implies that so long as clkusr pin has valid clock signal then transceivers will still calibrate correctly even when the global assignment is applied to suppress the critical warning... Digging through the Platform Designer synthesis files I found:
(*altera_attribute = "-name SDC_STATEMENT \"if { [get_collection_size [get_pins -compatibility_mode -nowarn ~ALTERA_CLKUSR~~ibuf|o]] > 0 } { create_clock -name ~ALTERA_CLKUSR~ -period 8 [get_pins -compatibility_mode -nowarn ~ALTERA_CLKUSR~~ibuf|o] }\"" *)in "altera_a10_xcvr_reset_sequencer_211\synth\alt_sld_fab_altera_a10_xcvr_reset_sequencer_211_33t7nri.v"
- FvM
Hi Steve,
I'm not quite sure where 125 MHz comes from may be it's a default. You can include CLKUSR as top level pin in your design and assign 100 MHz clock in .sdc. The specification should be used for all instances of automatic "~ALTERA_CLKUSR~" signal in your design.
Thanks Frank -- seems straightforward -- couple of questions before I fire up quartus -- is there any consequences for being explicit on this pin -- also any chance this clock is useable in the user logic as this would be useful "free" clock source?
