8 years agoHow to solve silicon id error?
i get the following whilw flashing
Error (209025): Can't recognize silicon ID for device 2. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.6 Replies
- MSeme2
In my case, I made a mistake in MSEL switches configuration.
Check the latest version document 2.0 http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=205&no=1046&partno=4 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
--- Quote Start --- Hi, ;);) So only, I have asked for the Dev kit information! okay, share me the user guide/Kit information? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Its DE10 Nano kit. check the chapter 8 https://software.intel.com/en-us/articles/de10-nano-development-board-user-manual - Altera_Forum
;);) So only, I have asked for the Dev kit information! okay, share me the user guide/Kit information? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
--- Quote Start --- Hi, If you are using USB blaster II can you change the TCK frequency and check once? https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06242013_922.html Which dev kit are you using? Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- The problem is with the tutorial itself. In official guides like "My first FPGA" you have stated to select EPCS128 as the eeprom chip which is wrong. In reality when i checked the ic in my hardware it was stated as ECPS64. Changing this in the settings solved my problem. - Altera_Forum
