8 years agoHow to solve silicon id error?
i get the following whilw flashing Error (209025): Can't recognize silicon ID for device 2. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, s...
8 years agoHi,
If you are using USB blaster II can you change the TCK frequency and check once? https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06242013_922.html Which dev kit are you using? Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
