syang97
6 years agoHow to set up Cyclon 10gx transceiver 10g base SR (Short Range 850nm MMF)/LR(Long Range 1310nmSMF )/ER?
Hello, I'm using the device of cyclon10gx, and I use the high-speed transceiver in it. My preset protocol is 10g base r..However, one of my clients USES an xilinx FPGA,We'll have optical communicat...
Deshi_Intel
6 years agoHI,
The SR and LR in NativePHY IP basically means short range (chip to chip) setting and long range (chip to backplane) setting irrespective of protocol.
- FPGA to SFP is consider as "chip to chip" connection
- So, you should set it to SR for your case
Regarding BER error debug
- Perhaps you can try enable PHY loopback to isolate is this board related issue or FPGA internal issue first
For the data swap issue and not data corruption issue
- If you look at page 100 on all the PMA/PCS blocked enabled for 10GBASE-R preset.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/ug_cyclone10_xcvr_phy.pdf
- I don't see any block functionality that can swap data. You may want to check is it your own user logic code issue or maybe Ethernet MAC issue.
- You can also consider to change the payload data pattern to see if it makes a difference or for ease of debug
dlim
