16 years agohow to set the differential pin (I/O standard LVDS_E_3R) TO ZERO ?
I am using cyclone 3. I need a pair of differential output pins at bank 4. According to the datasheet, I choose LVDS_E_3R for the I/O standard. when I debug the design, I set the signal which connected to the differential pin(LVDS_E_3R )to zero, and then compile the project,programme to the FPGA, but the output still perform like a high level.
HOW TO EXPLAIN THIS ? THANK YOU!2 Replies
Thanks for your reply!
I confirm that I do not measure the wrong output pin. when I set the (pseudo)LVDS ouput to a signal ‘reset’ (the default value is low), output(P) is low and output (N) is high. But I set the (pseudo)LVDS ouput to constant number '0',output(P) is high and output (N) is low. So I feel confused, I will check the performance of other (pseudo)LVDS. - Altera_Forum
When using (pseudo)LVDS, you'll get an (P) and an (N) output.
So if you assign a '0' to this output, (P) will be low and (N) will be high. If you measure a high when expecting a low, you are probably measuring the wrong output pin. -- Ton
