16 years agohow to set the differential pin (I/O standard LVDS_E_3R) TO ZERO ?
I am using cyclone 3. I need a pair of differential output pins at bank 4. According to the datasheet, I choose LVDS_E_3R for the I/O standard. when I debug the design, I set the signal which connect...
16 years agoThanks for your reply!
I confirm that I do not measure the wrong output pin. when I set the (pseudo)LVDS ouput to a signal ‘reset’ (the default value is low), output(P) is low and output (N) is high. But I set the (pseudo)LVDS ouput to constant number '0',output(P) is high and output (N) is low. So I feel confused, I will check the performance of other (pseudo)LVDS.
