16 years agoHow to set path system variable?
Hi everyone,
Whenever I start a "new project -> Nios II C/C++ Application", the following message appears on top of the window: No project template folders found in $SOPC_KIT_NIOS2/examples/software. Please ensure your environment variables are correctly set. I've created a new system variable (you know: My PC -> Advanced setup -> environment variables), both for my user and as general system variable, but it doesn't work. By the way: the name of the variable is SOPC_KIT_NIOS2 and its content is C:\Archivos de programa\altera\90\nios2eds (Spanish version of Windows XP ;) ) Anyone can help? Thanx in advance!4 Replies
I did what you told me: I re-installed both the Nios II EDS and the Quartus II software, this time on the default directory (c:\altera). Now everything works just fine. Thanks for the advice! Regards, Ismael - Altera_Forum
Get rid of the spaces in your path...re-install. They _will_ cause problems and are documented (I believe) as being disallowed.
Cheers, - slacker - Altera_Forum
I'm afraid that's not the problem. I have some others with the same starting directory, e.g. Variable: QUARTUS_ROOTDIR Value: c:\archivos de programa\altera\90sp2\quartus I've tried uppercase and lowercase, and that doesn't seem to be the problem. I'va also tried %20% instead of the spaces, but don't succeed neither :confused: Any help will be appreciated! Thanx. - Altera_Forum
Maybe this is due to your spaces in your path
"C:\Archivos de programa\altera\90\nios2eds"
