16 years agoHow to set path system variable?
Hi everyone, Whenever I start a "new project -> Nios II C/C++ Application", the following message appears on top of the window: No project template folders found in $SOPC_KIT_NIOS2/example...
16 years agoGet rid of the spaces in your path...re-install. They _will_ cause problems and are documented (I believe) as being disallowed.
Cheers, - slacker
