16 years agoHow to set path system variable?
Hi everyone, Whenever I start a "new project -> Nios II C/C++ Application", the following message appears on top of the window: No project template folders found in $SOPC_KIT_NIOS2/example...
16 years agoHi,
I'm afraid that's not the problem. I have some others with the same starting directory, e.g. Variable: QUARTUS_ROOTDIR Value: c:\archivos de programa\altera\90sp2\quartus I've tried uppercase and lowercase, and that doesn't seem to be the problem. I'va also tried %20% instead of the spaces, but don't succeed neither :confused: Any help will be appreciated! Thanx.
